Hello, after 1.5 years of using eisbaer 280 cooling I have a problem, recently my computer suddenly shut down due to overheating. I turned the computer on again and went into the bios where the cpu temperature was 80 *C and going up. I decided to replace the paste from the original one that came with the cooling to thermal grizzly kryonaut. After the exchange, the problem did not go away and the CPU temperature from 60 *C went up to 80-90*C in a matter of seconds (2-4 degrees per second). Then I thought that it could be the fault of the fluid. I scrubbed the whole system and poured in demineralized water. This gave the effect, because the computer at rest has 70 *C and at maximum load 90 *C and 1.5Ghz each on the core. After that I thought that maybe it was the fault of the pump where you could feel the flow of liquid, but I decided to turn it off manually while running at rest and the temperature automatically rose from 70 *C to 90 *C. I have run out of ideas but I noticed another thing. At maximum load the radiator is warm only at the heat inlet to it and the rest is at ambient temperature. After turning off the fans it gets warmer but it's very slow. I'll add that when I changed the fluid there was some contamination in it. Maybe the radiator got clogged? I'll add that when cleaning the cooling I forgot to clean the pump so maybe some of that dirt clogged that radiator and restricted the flow of liquid. One more thing does not room me, when I move the radiator in a violent way I can hear the overflow of liquid, in no way I can get rid of it. Please give me some advice.
CPU: Ryzen 9 5900x
Mobo: Crosshair VIII Hero
Edit #1
I also want to add that, for example, just open the browser and from 70 *C it becomes 90 *C
CPU: Ryzen 9 5900x
Edit #1
