morleyc
Dear support, on reciving my distro plate i found a piece of plastic inside, brand new out of the box... on checking the website i think this small plastic piece is from the pump that comes with the distro plate.
https://shop.alphacool.com/en/shop/pumpen/vpp-d5/13339-alphacool-vpp-apex-pump
Checking the image, it seems the white plastic is from the inside below, as mentioned the larger circle piece of plastic was already in the plate when I received it I thought this was a piece of packing or similar just emptied out the distro plate.
I don't have a picture of that piece, but is same colour looked like a plastic clip.
After running the system I then found the smaller part attached image on the outlet side of the pump on the distro plate.
The pump is working and water flowing but I do not want to take the risk, i raised a support request at the weekend and will look forward to hearing from you.
