Pump connection of Eisbaer 420 CPU to MSI Z590 Godlike
Rusorthodox
Unfortunately did not find any information neither in manual for Eisbaer 420CPU nor motherboard's one about what should I do with 3-pin power connector of the pump (fans are connected to CPU_Fan ok). I have Pump_Fan connector on my MB, but it is 4 pin and some guys in Asus support forum consider it too powerful for the pump. All Fan connectors are 4-pin.
So no information for decision anywhere.
Will appreciate any suggestions, my upgrade with Eisbaer device is on pause for several hours of internet surfing.
Luckystricker
Official Alphacool Staff
Hi @Rusorthodox
You can connect the pump connector to any fan connector on your mainboard. It would then only be important that the respective connection in the BIOS is set to DC (not PWM) and 100% so that the pump runs at full power. It doesn't matter whether it is a 3-pin connection or a 4-pin connection. Even if it is a pump connection with 3 amps or more, it does not matter because it is only the power that the connection can deliver at the most. The pump only takes the power it needs to run.
Best Regards
