Pump for new acrylic plate?
CycleChris
Hey. I love my eiswolf 6900xt kit. Im thinking about purchasing the new 7900xtx tiachi gpu. I see alphacool makes a block for the card. I’d like to avoid purchasing another radiator and fans. Can I purchase the pump thats built in the the card or do I just need to buy the pump with reservoir? Not worried about warranty on the eiswolf.
Thomas_S
We already have a cooler for the RX 7900XTX/XT Taichi:
Replacing the cooler on the AiO is possible in principle. However, we do not recommend this! The customer rarely gets the pump and cooler leak-proof again. Many Eiswölfe have ended up here for repair - in connection with high costs for the causer! The next problem is that the pump cover will probably no longer fit properly, as it is adapted to the respective cooler. Your decision ;-)
Thomas_S
Correct, you only have to mount the corresponding terminal on the cooler instead of the Eiswolf 2 pump. We have the terminal available in our shop.
