ByteCode64
Hi ,
i recently installed NexXxoS HPE-45 360mm Radiator, the issue is when i run it for 30+ minute (fan set at 100%) the water temp reaches 60+ even at idle and doesn't come down , both the inlet and outlet temperatures are same and very hot (unable to touch) , just to double check i turned off the fan , it remained the same , it seems the rad is not working and just bypassing water from inlet to outlet , at the other side of rad (drain port ) its cool.
Case is open , ambient temperature is around 20c
Setup :
Pump > GPU > CPU > RAD > Pump
Setup :
