Cayan
Hello!
I currently have a GPU Eiswolf block+pump inserted in my custom water loop that already has a D5 pump on it.
Keeping the Eiswolf pump on or off doesn't have any effect on the loop flow or temps.
I just keep the Eisblock Pump on the block because of the LED on the pump that looks great !
I'm wondering if keeping the Eiswolf pump on the block is causing any restriction in the flow...
I see that Alphacool has the Aurora terminal for GPU blocks, that can replace the Eiswolf pump and convert the GPU block to a full custom loop block.
Personally, I like the Eiswolf pump for the looks, but if that causes any restriction in the flow, I prefer to change it.
If I change the Eisblock pump with the Aurora GPU block terminal instead, will that has any impact on the overall flow of my loop?
Thanks
Thanks
