Replacement Eiszeit 2000 chiller water pump
Mr Tony
Hi, Sadly it seems the water pump on my Alphacool 2000 chiller has died ... The alarm goes off when starting and you can see no watervis circulating around the system.
Is it possible to buy a replacement water pump or to have a exact diagram layout to maybe source the component myself ... The chiller is at least 4 years old and I assume out of warranty but if I can repair rather than getting another cooling solution for my Threadripper 3
Regards
I can’t really help with that. Unfortunately, I can’t provide you with such information, and we don’t sell a replacement pump.
As long as nothing is leaking, you can also use an external pump. Many flow coolers or chillers don’t have an internal pump at all.
