BobbyBoyGaming
Member
Hello I have an Alphacool reservoir, and I cannot align the 120mm fan holes with the reservoir mounting holes.
The instruction manual shows the L-brackets pointing inward towards each other but the holes don't line up properly this way. I was wondering if I have to switch these L-brackets so that they point away from each other so that the holes will line up.
Or am I supposed to mount it differently? I want to know if it is okay for me to unscrew this reservoir tube (blue circles) or if it glued shut from the factory? I don't want to break this item so please let me know what is going on here.
I dont remember if it came assembled like this or if I put this together in this way.
