Reusing Eisbaer 360 for GPU cooling
Crocodil
Hi :)
I'm very new to watercooling but I very much like the idea of Alphacool's AIOs modularity. I wonder if there's a way (or what's the best way) to re-use Alphacool Eisbaer 360 for GPU cooling? I think it's not possible to get just the GPU block, backplate and pump part of Alphacool Eiswolf 2 AIO, right? If so, I basically can only use the radiator with fans and then I have to get a pump and GPU block, correct?
The question is probably not GPU specific, but just in case - I own a Sapphire Radeon RX 7900 XTX Nitro+.
Best regards,
Crocodil
astaaa
Administrator
Hi, yes you can use the eisbaer for cooling you GPU. There for you need the GPU Block, a pump and the backplate but It would be easier if you buy a new AIO for the GPU.
