RGB conncetor issue
Picota92
Hello all,
I'm about to build my loop and ive got almost everything ready.
My GPU block form Alphacool is THIS but i have no idea how or where to connect it. I think its meant to be connected to a Alphacool controller i guess, but its kinda a pain in the ass since i already have a controller for the Lian-li fans.
Is there any way like a cable to change the connector or something that i can use to change that? Or am i gonna need the Alphacool controller no mater what?
Thank you very much!
Vanzin
This is a normal 3Pin JST aRGB connector which you can connect to every 5V aRGB controller like your motherboard or following controller. A adapter from 3Pin jst to 4-1 aRGB, which the most controller are using is also included to the water block.
Picota92
Thank you very much! I think i follow but to be 100% sure.
I realized the GPU block came with another cable that i can connect to the GPU Block so it LOOKS LIKE THIS
Is it enough like this or do i have to connect the other connector that comes out of the GPU block as well?
Thank you
