Hi, I have a spare GPX solo (my pump went bad for my Eiswolf). I was also fortunate enough to be near the top of the list for an EVGA 3090 Kingpin Hybrid. Because I'm building a full custom loop I'm hoping someone will make a full water block for this card. However, in the mean time, what I want to do is fabricate a new bracket for the GPX Solo to mount it to the RTX 3090 kingpin. I've pulled the impeller out so it will act like a passive water block.
I understand the GPX Solo is no longer supported and you won't be making new adapters plates for it. I have access to a CNC machine so I want to make my own adapter plate that will mate to the GPX and the Kingpin card. While I wait for my card to show up if I could get the dimension of the mounting holes and distance from the chip center I could start work on making the stl for this. Can someone here please provide me with the mounting whole dimensions (HxW) and chip distance.
Thanks, Jeff
Thanks, Jeff
