Heyo,
So I've got this block installed on my Sapphire Pulse RX 5700XT. Overall, I'm delighted with the performance. GPU/Hotspot and Power Delivery temps are all great
Memory temps not so much. They'll hit high 80s under load, mid-90s under Furmark, and 100 while Ethereum mining - that's a new Worst Case thermal workload for me!
Based on previous threads here, I presume replacing the supplied memory thermal pads will improve this, but disassembling this system is a pain in the ass and I don't want to do it more than once, hence:
Has anyone else corrected issues like this in the past, and if so can you advice the correct products to buy? The documentation indicates that all pads included with the block are 1mm thick. Assuming that's thick enough (Haven't disassembled to look for compression) then I would expect any high-conductivity 1mm thick pads to be suitable. Does anyone know the W/mk of the included pads?
