Kyuss
Hi,
After the second attempt of mounting the Eiswolf block in my KFA2 RTX 4090 I can see that my gpu is not fully compatible with the reference block despite the alphacool configurator.
Every hole but the two holding the GPU bracket are in place, one of them is usable as it falls into the screw area, but the other is totally offset. The hole of the card bracket located between the ports and the pcie is not aligned. So, I'm with a bittersweet feeling, I like the unique configuration and performance of these aios but there is something wrong here.
Anyone have this card and this block to check it please?
