If your GPU is affected with the GPU DIE sitting different as Nvidia is saying. You will need softer Pads not thinner ones. We are speaking here about 0,1-0,2mm difference. This will cause that hard 1mm Pads are to thick and 0,75mm PAds are to thinn. Therefore is your GPU is affected with the problem contact us info@alphacool.com so that we can check and send you the special softer pads to solve the problem.
