UV reactive liquids
GuntherMSI
Hi all,
I just bought myself an Eisbear Black AIO 360, this is a basic loop for now.
In the future I will expand this loop with a reservoir/ pump, a CPU water block and hard tubes, I noticed under all products that only clear water need to be used.
But I noticed colored coolants from Alphacool. Does that mean I cannot use these coolants for the custom loop.
Or do I understand this wrong? I'm new to this, so I'm a little confused. Can anyone help me out?
Thank you very much.
Gunther
David_ALC
Moderator / Trainee
Hey,
we recommend to only use clear cooling liquids to prevent the cooling components of deposits. In colored coolants the particles in the system can clog the fins so that the performance of the cooler is not guaranteed.
You can use our colored coolants but be aware that you might have to maintain the system very often.
My personal tip: avoid colored liquids.
