Much appreciation for the help. I decided to build my first custom loop in my miniITX case and the last thing I need to choose are the fittings. But when I try to figure out the size of the fittings I got lost. I need 2 straight compression fittings and 2 90° compression fittings. When I take a look at the datasheet of the tube it says that the inner diameter is 11mm or 7/16", also it says that it is perfect for a 11/8 system. With that, I would like an advice.
Again I appreciate the help. Cheers.
