Alphacool Eiswolf 2 AIO - 360mm RTX 3090/3080 with Backplate (Reference) available now!
Makes no sense. A 3080 with ~350W.... with OC over 400W and more with only a 240mm radiator? We can do it, with some enterprise fans with over 4000rpm. Otherwise the cooling performance will be a problem.
Please consider selling a version of eiswolf 2 for the rtx3080 without a radiator.
i also don’t have Space in my case for a 360mm Rad… but I already own a alphacool eisbaer 240mm for my cpu, I want to put the graphics card into the loop together with another 240mm radiator. So that should be fine, but im not willing to buy a set with a 360mm radiator just to buy another one. And I would also love to have the eiswolf gpu pump to not stress my cpu pump for the full loop. Hope you can consider it at least.
greetings
carsten
It is not currently on the planning list. The simple reason is that we are still barely able to process the orders. It is not worthwhile to offer another version without a radiator here if we can hardly handle the orders for the version with a radiator. If the situation improves at some point, that will certainly come.
I have a new case now and could put a 360mm GPU cooler :)
I have a Gigabyte Eagle 3080, from what I've read it uses the Nvidia reference design, so I suppose I can install the Eiswolf2 on it ?
+ What fans do you use on the Eiswolf2 rad ? I've swapped the ones from my Eisbaer 280mm (standard version) to Arctic P14s and it's now around 5c less over the board, at equivalent noise level...
mhh okay, considering the price for the full package it’s really good offer.
can I buy the eiswolf2 with the 360mm radiator and order the Alphacool NexXxos Eiswolf / Eisbaer Ready ST30 Full Copper 240mm Radiator and change it afterwords ? Is it compatible with the quick release ? Because the tubes look different. Also the tubes from my eisbaer 2 look different, wonder if it is all compatible. If yes I might be ordering both and selling the 360mm radiator.
thanks for the answer
Eddy -
I'd love to use a different, slimmer radiator and slimmer tubing without the quick release junctions. Is this possible with the Alphacool fittings?
@Bam2000
Yes you can change it. And yes, the QDCs on all prefilled radiators are looking different, but they are compatible to Eisbaer, Eiswolf and Eiswand.
@n00bm4s7er
Sure.
I am also very curious about when it's going to be back in stock. It seems like the "in stock counter" just goes to "delivery date exceeded" and is then updated with a new date.
Hoping someone can shed more light on this.
Edit: I just got a notification that it has been shipped. So apparently they did get an amount of coolers to send to those that have already ordered it.
Hi mates
I see there's a Eiswolf block for the Gigabyte 3080 Gaming, would that fit a 3080 Eagle ? Cards are pretty close to one another ...
Compatibility list:
Nvidia RTX 3080/3090 graphics cards using the reference design
These include, but are not limited to:
RTX 3080
Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXMPB)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXPPB)
Inno3D GeForce RTX 3080 iChill X4 10240 MB GDDR6X (C30804-106XX-1810VA36)
Inno3D GeForce RTX 3080 Twin X2 OC 10240 MB GDDR6X (N30802-106XX-1810VA34)
Inno3D GeForce RTX 3080 iChill X3 10240 MB GDDR6X (C30803-106XX-1810VA37)
Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
Galax GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NN)
KFA2 GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NK)
Gainward RTX 3080 Phoenix
Gainward RTX 3080 Phoenix GS
RTX 3090
PNY GeForce RTX 3090 XLR8 Gaming EPIC-X RGB, 24576 MB GDDR6X (VCG309024TFXPPB)
Inno3D GeForce RTX 3090 iChill X3, 24576 MB GDDR6X (C30903-246XX-1880VA37)
Inno3D GeForce RTX 3090 Gaming X3, 24576 MB GDDR6X (N30903-246X-1880VA37N)
Inno3D GeForce RTX 3090 iChill X4, 24576 MB GDDR6X (C30904-246XX-1880VA36)
Zotac GeForce RTX 3090 Trinity, 24576 MB GDDR6X (ZT-A30900D-10P)
Palit GeForce RTX™ 3080 GamingPro (NED3090019SB-132BA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3090S19SB-132BA)
Galax GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/ (39NSM5MD1GNA)
KFA2 GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/
Gainward RTX 3090 Phoenix
Gainward RTX 3090 Phoenix GS
Further infos in our Shop: https://www.alphacool.com/shop/aios...tx-3090/3080-with-backplate-reference?c=21538
hey when will the Aio be compatiable for Gigabyte GeForce RTX 3090 Gaming OC 24G, 24GB GDDR6X, 2x HDMI, 3x DP
GV-N3090GAMING OC-24GD
im currently seach for it and willing to preorder it if its possible . what about 240/280 be availble ?
Maybe end of this month for the Gigabyte Gaming OC. 240 and 280mm Eiswolf versions? We will not offer that, only 360mm versions. The only 240mm version will be "maybe" as RTX 3070 AIO.
Back
