Alphacool Eiswolf 2 AIO - 360mm RTX 3090/3080 with Backplate (Reference) available now!
Thomas_S
Moderator
Compatibility list:
Nvidia RTX 3080/3090 graphics cards using the reference design
These include, but are not limited to:
RTX 3080
Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXMPB)
PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB 10240 MB GDDR6X (VCG308010TFXPPB)
Inno3D GeForce RTX 3080 iChill X4 10240 MB GDDR6X (C30804-106XX-1810VA36)
Inno3D GeForce RTX 3080 Twin X2 OC 10240 MB GDDR6X (N30802-106XX-1810VA34)
Inno3D GeForce RTX 3080 iChill X3 10240 MB GDDR6X (C30803-106XX-1810VA37)
Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
Galax GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NN)
KFA2 GeForce RTX 3080 SG 10GB GDDR6X 320-bit DP*3/HDMI (38NWM3MD99NK)
Gainward RTX 3080 Phoenix
Gainward RTX 3080 Phoenix GS
RTX 3090
PNY GeForce RTX 3090 XLR8 Gaming EPIC-X RGB, 24576 MB GDDR6X (VCG309024TFXPPB)
Inno3D GeForce RTX 3090 iChill X3, 24576 MB GDDR6X (C30903-246XX-1880VA37)
Inno3D GeForce RTX 3090 Gaming X3, 24576 MB GDDR6X (N30903-246X-1880VA37N)
Inno3D GeForce RTX 3090 iChill X4, 24576 MB GDDR6X (C30904-246XX-1880VA36)
Zotac GeForce RTX 3090 Trinity, 24576 MB GDDR6X (ZT-A30900D-10P)
Palit GeForce RTX™ 3080 GamingPro (NED3090019SB-132BA)
Palit GeForce RTX™ 3080 GamingPro OC (NED3090S19SB-132BA)
Galax GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/ (39NSM5MD1GNA)
KFA2 GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/
Gainward RTX 3090 Phoenix
Gainward RTX 3090 Phoenix GS
Further infos in our Shop: https://www.alphacool.com/shop/aios...tx-3090/3080-with-backplate-reference?c=21538
danfullstop
Bought and on route!!! Thank you Alphacool been looking forward to this since I had the delight of using my standard Zotac cooler... :) :) :)
Bullant
Already ordered and paid for, but I am wondering if you did any performance testing? Particularly keen to hear of VRAM junction temps on a 3090 at full load (mining). Really hope I can unlock the full potential of my very expensive card!
We checked our cooler on 3090 cards long before Nvidia made the release, also some board partners have checked it.
Makes no sense. A 3080 with ~350W.... with OC over 400W and more with only a 240mm radiator? We can do it, with some enterprise fans with over 4000rpm. Otherwise the cooling performance will be a problem.
danfullstop
can you feedback on how its impacted your thermals?
Yup no problem, will post back when I have a chance to play with it properly. I will have it tomorrow after paying the suprise £54 import charges, thanks brexit lol. This is what I get for not waiting for it to be available from a UK retailer but there you go :)
Granville
Oh man, thats harsh. Did you order direct? I was looking at ordering from aqua tuning UK, so i hope that wont happen with them?
danfullstop
Yeh direct, came really quick though but not a cheap experience. I also saw it on Aquatuning but after I bought it... although their site and Alphacools site are near identical so I assumed they are one in the same company? Haven’t looked into it tbh but the aquatuning price is about £70-80 less than I paid in total 😂
Granville
still good value vs. custom loop. I hope the performance matches your expectations. Really interested to hear. Are you using the 3080 or 3090 Zotac? I considering this for a 3080 Palit gaming OC.
danfullstop
Yeh I used to run custom loops years ago but in honesty I can't be arsed anymore, my CPU AIO is brilliant so hoping for the same here (minus the lack of rear DIMM active cooling). I have a 3090 Zotac, with probably the worst cooler ive ever had in recent years attached to it.
For your 3080 this will be perfect as you dont need to worry about the extra DIMM's on the rear of the card that this doesn’t cover (other than a passive backplate), im still expecting much better clocks than im currently running though. I've flashed mine with the Giga OC bios undervolted @ 850mV to get a 100% stable 1830mhz which still gives me great performance, surpassing lots of other cards with better coolers, im just not happy about how loud and hot the core can get at times, so im hoping along with resolving that I can get abit more performance from it. Ill remove the undervolt and just let it boost away and see where it is with the lower temps to start with. The biggest issue ill have is actually fitting the rad in my case as its not rated to actually fit 2 x 360mm rads, but im sure ill make it work.. somehow.
Ill post back tomorrow assuming I get the time to fit it later tonight :)
danfullstop
So I installed this last night, had a slight issue in that I can fit the rad in my case with the other 360 but with only 2 fans... I do however also have 2 x 140mm fans blowing air directly at it but still not ideal. Anyway, like for like GPU clocks and voltages im seeing around 20-25c lower core temps and 7-8c lower memory, remember that my 3090 has memory on the rear so that highest temp will be coming from the passively cooled backplate, which is still clearly doing a better job than the Zotac one.
Im happy with it, would be better if I could hook up 3 fans but I physically don’t have the space, the install was very easy I just took my time to avoid any silly mistakes.
