tomato112233
hi i have aurora 280 I want to purchase new Nvidea or amd gpu how do I expand that aio to cover a gpu waterblock i only have enough room for another 120mm radiator if needed
OK what if added a GPU cooler another 120mm radiator on the exhaust and additional pipping would the pump on the CPU Eisbear support this setup?Hi, you need an Eiswolf to expand the system or you need a GPU block and our extension kits to plug both systems together. But i am not sure that the radiator would be enough to cool the GPU.
Cool. Will you have more stock of eiswolf 2 soon???Eiswolf 1 is EOL. We will not make any Eiswolf 1 cooler anymore, only Eiswolf 2.
ETA is the 28.09.2020Also when will it be in stock?
I did not get this question. Can you please explain more detailed?Can you change the waterblock and keep the pump for future generations?
At the moment we have it only with the 240 mm radiator.Can you supply with a 360mm radiator?
If I upgrade to a 3080 from 2080 can I change the waterblock in the eiswolf to fit?ETA is the 28.09.2020
