information aio watercooling loop
Bacara1138
Hello !
I currently own an
Alphacool Eiswolf 2 AIO 360mm RTX 4090
Alphacool Eisbaer Pro Aurora 360 AIO loop.
I want to add a tank with a pump.
I found these two items,
Alphacool Eisbecher D5 250mm Acetal inkl. 1x Alphacool VPP655
Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit Apex Pumpe.
My question is the following.
Does adding the reservoir pumps risk damaging the CPU and GPU cooling? can the pipes withstand the pressure?
Thank you
