Because if I change graphics cards, I will have to get new pcie PSU cables.a nice build ,I like the fact that you use 2 reservoirs, but why don't you use 8-hole combs everywhere for your graphics cards cable ?
I totally agree. Luckily I have fittings and tubing to add it if I do. And enough PSU and pump header connectors as well.XD if you win one of those Eisballs you should squeeze it in the bottom there off one of those fan mounts 3 D5 better then 2? XD so much head!
I started with a budget build and slowly evolved it over 10 years to where it is today.Realy awesome build! I hope anytime soon i will have enough money to build my own :/
It is a Thermaltake W200.I am sure you have been asked this before and I missed it somewhere, but what case is that ?![]()
Just thought I would share my progress on my case/loop upgrade.
Will be filling and testing this weekend.
Will need quite a bit of liquid Showbox jiofi.local.html tplinklogin to fill as I am sporting four Alphacool 480mm and one 240mm radiators, two reservoirs.
Hopefully no leaks and I will be good to go for summer.
I assume kind of filter or strainerWhat is inside the resevoirs?
