@MDK_pt bro, if you have the MSI 4090 Suprim X, since it has 26 power stages, if you see Actually Hardcore Overclocking talked about the GPU PCB Breakdown of this card:
at 18:10
The heat produced is very small per power stage.
In my Speed Way stress test without any modifications (Afterburner for example), the card draws 404W with 1.05V => ~384A -> still be able to cool themselves
passively according to the video.
So, in conclusion, if you like the aesthetic of the Aurora, buy it. The core model has the same water path layout, but copper plate extended to cover the whole card. I'm pretty sure there is no performance gain if compared to the Aurora, although it's much more expensive.
Another reason to choose the Aurora is I bought both the EKWB GPU waterblock and the Aurora, and the Aurora is noticeable heavier. Don't need to make it even heavier by using the core model.
I'm happy with my Aurora now
@Vanzin @Eddy . Although if you make it less heavy it would be better.
PS: And FYI, I still don't receive the fix for the card although you wrote that you sent it to me on May 25. Why the hell do you use such bs delivery service Maxi Letter???
