Which contact frame or backplate for LGA 1700 and Eisblock XPX Aurora Edge Acryl Black ?
deadpixel
I already have the Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB.
It is for an MSI Pro Z790-A WIFI DDR4 mainboard with I7 13700 K.
I read, that to prevent bending of the mainboard and / or cpu, a backplate and / or contact frame should be used.
Regarding backplates I found:
and
Price difference is more than 100% between them but description indicates both do the same thing?
So what is the difference exept from the price?
Regarding contact frame:
If I use a backplate should I still get a contact frame? If yes, is there one in the shop that is compatible with my waterblock and the mentioned backplates?
Vanzin
HI,
The Core Version is the normal Backplate, which is also included in our products. The Apex Version is replacing the original Backplate and stabilise the motherboard much more to avoid the bending problem. If you can use a contact frame with our water blocks I can´t say, since we are not the manufacturer of it, we can´t say if you can mount our water block as intented.
