• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
'Gainward Phantom, Phantom GS, Palit GameRock, GameRock OC RTX 3090, 3080 waterblocks'
Thomas_S
Administrator
@Junglst I have talked to our support team about the SLI connector. So far, there have been no problems of this kind. So yours seems to be an individual case.
manuumanu559
I'm not sure how you assess whether it is worth while making a block for a card, but the Gamerock has been one of the only top tier cards readily available in the UK thus far so I expect that there will be a fair market share!
uc browser turbo jio login
church
Active member
Playasavas: 3070, as cheaper cards, are more common, but their owners are often less willing to shell out extra money for LC. They often also "need less cooling" and are often OK cooling noise wise on air cooling. Best way would be to get one of many of "reference design" there are already numerous blocks available. For these reasons i see little chance for one of non-ref 3070 niche cards to see blocks made for (except normal top tier list of asus/msi/gigabyte/evga and alikes..)
Grey_4_Lance
Hi @Eddy, @Thomas_S. How are you doing with the active backplate? Last time you mentioned that this work had to be started over due to the unsatisfactory result of the engineering sample. Can we hope that this work has not been put on the table?
church
Active member
Patience? What's that? :)
BurritoJustice
I have this block on my 3080 Phantom GS and my memory temps are very poor, 92C+. Is there anything to be done about this other than buy high performance pads?
Thomas_S
Administrator
First determine whether you are affected by Nvidia's package problems (the attached video explains it well if the problem is not yet known)! It can happen that components do not have sufficient contact with the thermal pads. We can clarify this by sending us pictures of your PCB showing the marks on the thermal pads. If a replacement is necessary, our support team will send you the right pads quickly and free of charge.
BurritoJustice
Thanks for the quick response! I think it is likely to be the problem, as it seems strange to have such poor temps when I have great core temps relative to coolant. I'm guessing the remedy is slightly thicker pads (1.5)? After christmas, when I have the time, I'll pull apart my loop to take photos of the PCB for support.
Thomas_S
Administrator
Perfect, just upload them here in the forum (at best in a separate post). Then we can immediately see if you need other pads ;-)
